Feature Request - Multiplus / VE Configure Panel
Problem - The panel wording does not clearly describe the behaviour of the Aux Relay’s Normally Open and Normally Closed contacts in response the the state of the Virtual Switch.
Request - May I respectfully request the wording on the above panel be modified such that it clearly describes the behaviour of the Aux Relay’s Normally Open and Normally Closed contacts in response the the state of the Virtual Switch?
Suggestion - See panel below
@DavidQ good to see feedback to continuously improve a product but doesn’t the existing wording perfectly
describe the actions of the relay?
Open (as in open circuit) or closed ( as in closed circuit) tells what the relay contacts are doing in response to the Virtual Switch status.
Hey Trevor. It would IF there was only ONE contact. There are TWO : a NORMALLY OPEN contact and a NORMALLY CLOSED contact.
So what does “VS on = open” mean? Does it mean the NO contact is open or does it mean the NC contact is open?
David
Exactly Ludo
@DavidQ oh, yes, I missed the point……that is confusing. On=open is not normal convention is it. Thanks for clarifying.
