Feature Request - GUI Changes
I’ve been loving the new GUI for the most part, but there’s a couple changes that I think would be big improvements:
  1. AC Voltage - This isn’t visible anywhere. I’d expect to see it on the Overview page on the AC input blocks, or at a minimum on the detail page when tapping either the AC input block or the Inverter block. This is vital information for anyone hooking up to potentially unreliable grids, like in an RV park.
  2. Battery Percentage/Levels on the Brief page - When there are only a few level sensors available the battery percentage is shown in the center as a number. Once there are more than a couple that number goes away and you just get 4 rings. It would be great if we could have those 4 rings as tank levels and still get the battery percentage displayed in the middle of them. I (like just about everyone in an RV) have 3 water tanks and propane level to keep an eye on. Having those 4 tank levels visible on the brief page at the same time, while not giving up the ability to see the battery % would be quite helpful.
Definitely agree re: AC Voltages. L1, L2, In and Out. All that.
Please add on the Overview screen:
  1. AC Voltage
  2. AC Frequency (especialy in off-grid with PV on output where PV-output is reduced with increased frequency by PV-assistant)
  3. Option to select both Power (Watt) AND Current (Ampere) displayed. I notice in parallel system that Power is indicated correctly (sum of 2 parallel quattros) but Current displayed is 2 x master current (but this is not always equal for both quattros, depending on small cable differences etc…so Slave current on AC IN can be lower or higher than on Master, which is rather inconvenient to set a current limit for shore power connection on a boat)
    For these reasons, I stay on 3.42 with GuiMods.
These views are needed. Remote console brief display shows Generator (input 1) but not Shore Power (input 2). Generator and Shore Power are both presented on the Remote Console Overview and the VRM Dashboard.
I tested this in a few systems.
Clicking on the grid tile opens details from the grid meter with voltage, current and power.
Clicking on the MultiPlus tile opens details from the MultiPlus with voltage, current, power and frequency.
Matthias,
My system with a MP-II 2x120v doesn’t show the same data. I do not have a separate grid meter.
Overview
Shore power drill down screen
Multiplus drill down screen
What do you see if you click on “product page”?
You are running a beta software.
I’ll check the product page link tomorrow.
Yes, I am running 3.60~25. I posted this in the beta forum but it got moved.
If I hit “Product Page” I get the same screen that I get when tapping the shore connection box.
Love this!
I tested this on another system with an MP II 2x120 that is not running beta software and confirmed that it also doesn’t show AC voltage.
Venus 3.6~25 with MP2 48/3000/35:
This is a double click on the inverter tile. No grid meter.
Note: AC in is connected to the inverter, but the inverter is set to invert only.
Perhaps this is an issue when there is more than one inverter in the system, such as a parallel or ani-phase pair. I’ve found that a Mk3 will give inaccurate data when used with a parallel pair (Mk3 frames give current from a single inverter rather than the sum of both)
Mike,
My system only has a single inverter. Maybe it’s a 120v system bug? I haven’t seen anyone post up with voltage showing on a 120v.
@M_Lange
I’m still seeing the same thing in the latest beta version, and I’ve rolled back to the release version and it’s exactly the same. No matter what software I’m running there’s no AC voltage information from my Multiplus 2 2x120v.
