Feature request Blue smart charger ip67
Hi
We run an number (50+) of smart chargers ip67 24V 8A in our company to charge measurement devices.
Normally we connect the equipment and then switch on the charger and everything works as intended.
In the rare case when equipment is disconnected while the charger is left powered and new equipment is connected, the charger doesn’t initiate charging right away but restarting it by power cycling works.
Is there a way to immediately initiate charging after a switch of batteries is registered ?
An implementation via firmware would be highly appreciated if there is no workaround.
Thanks
Have you tried setting the rebulk current?
not yet! what triggers a rebulk ?
Well the rebulk current does, but all triggers are listed in the manual section above
Thank you for helping :slight_smile: Setting the voltage levels for float lower and the rebulk current relatively low worked perfect !
