Feature Request: Ability to override Tank Pump in switches icon
Hi There,
I have one of my GX relays setup as a tank pump in our camper that is sometimes connected to an external water bladder. The whole bladder/pump setup is removeable with a connector on the side of the camper. The Ekrano is configured to kick the pump in at 50% and out at 80%, and is usually set to “auto” mode.
It would be nice to have the ability to override this setting without needing to go through all the menus. Potentially via the same menu that gives you the ability to toggle the inverter on/off. Just the ability to switch between “On”, “Off” and “Auto” would be handy, as sometimes it would be good to be able to override the setting at times. When the bladder gets low it’s handy to be able to stop the pump via the UI from my phone, rather than unplugging it when the bladder is empty while pumping the last of the water into the camper. Likewise when first plugging it in it’s handy to wait until the bladder has been filled before toggling it to the “Auto” setting.
Thanks,
Josh
I’m also keen on this option. It is available in the old user interface.. the relay 2 is available in the quick menu, top left corner..
