Hi, I have hooked up the Relay functions on the Cerbo GX to control two pieces of equipment.
Is it possible to add functionality to rename these from Relay 1 Relay 2 to whatever suits your site.
If you’re using GUI v1 then you can install @kwindrem his GUI mod, then you have a dedicated relays page, and you can also rename them.
If you’re using GUI v2 then you have to wait for a dedicated relays page to be implemented. In the GUI v2 Beta version topic, Victron @mpvader wrote that this request is on the radar.
I hope this option will be implemented soon, and till then I stick to GUI v1 with the GUI mod.
Here’s the same request: Eigener Name für Relais, Dig Inputs und so - #2 by Theo
@victron any news on renaming relais?
@kwindrem is it possible with your GuiMods?
With GuiMods for the Venos OS with the old GUI, it’s possible to rename the relays, and to switch them both manually. The GuiMod add’s an extra dedicated Relays page to the software.
This is the reason I stick to Venus OS with the old GUI for the time being.
For Github:
NOTE: starting with firmware v3.50, the “New UI” (aka gui-v2) is available for use
For GuiMods, the following opitons must be configured via Classic UI
but will continue to function after switching back to New UI:
configutaiton of the External transfer switch digital input
syncronizing the generator manual run to the generator digital input
PackageManager menus are also available only in Classic UI
+1, waiting for this feature
Hey,
Naming the built-in relays and having them easily accessible for daily control is coming.
And at this moment available for beta testing and feedback: V3.70 betas: internal relays moved to the Switch pane
