feature-request venus-os cerbo-gx node-red marine
It would be useful if GX Digital Inputs could optionally be configured as action buttons instead of only alarm/status inputs.
Examples:
  • Toggle Relay 1 or Relay 2
  • Turn a relay ON for a configurable duration
  • Turn an inverter ON for a configurable duration
  • Activate a Virtual Switch
Typical use cases:
  • Inverter ON for 60 minutes
  • Water heater ON for 10 minutes
  • Simple push-button automation in marine and RV installations
Today these functions require Node-RED. A built-in Action mode for Digital Inputs would make common use cases much easier to implement while still leaving Node-RED available for advanced automation.
