I recently connected a Victron EV charger to the AC-in (the display in the charger is wrong but in vrm it is correct)
Unfortunately I get a W-106 Overload Active and the charging speed also goes down. I have set the Charger to a max of16A and the multiplus is set to 25A (I have a 3x 25A Grid connection)
So in my opinion everything is correct. Do you have an idea why this message is given?
Hello @eguliker.
Regarding the ‘W-106 Overload message’. Can you please check the ‘Input current limit’ on the settings->GX device page and increase it. For the ‘AC-in’ mode, EVCS has its own option for limit calculation. By default, it is 15A, which may be too small for your system.
