EVCS not following input limit, overload protection enabled
I’ve got 3 Victron EVCS chargers on one Cerbo GX.
In each EVCS charger the Input current limit is set with overload protection enabled.
This has worked great for a long time, not overthrowing the limited grid connection power / amps.
Recently I had some trouble with what seems to have been CP calibration, but it has been resolved.
By doing several factory resets and moving to the latest firmware which is now 2.05
But now, with the same three EVCS units and the same three EVs, this one is not following the input current limit anymore.
The EV is following the EVCS, in that it follows the max amps when I change that manually.
However, unlike before, one of the three doesn’t follow the input current limit set, through the GX device.
It just ignores the setting and charges way to fast.
I’ve gone back to 2.04 firmware, and I’ve also disabled and re-enabled GX communication, but no change.
I’ve checked all the settings, and there is no difference to the other two, or to it’s earlier configuration.
Meaning that the input current limit is set, and the overload protection is enabled. For all three EVCS units.
There is no battery in this setup, and all EVCS units are configured on being located at AC-input.
I’m unsure what to check next, or what to do about it.
