I would need some of our EVCS in the Beta release Update feed. I can´t find the button to switch the feed. Can someone help me?
Can nobody really help me? We’ve already updated 3 of our 12 EVCS stations to the beta release update feed. The beta version solved our problem—but only on those 3 charging stations. It’s really frustrating knowing there’s a solution, but I can’t access it. Nicolas installed the updates on those 3 stations 3 months ago. Unfortunately, I haven’t been able to reach him since.
Maybe add a bit more information?
add some pictures of what you mean is not working, so that people can simply help you!
The problem is the communication over Modbus between Cerbo and EVCS. I habe 250KWp PV and if more than 33000 Watts per Phase goes into the grid the value goes from -33000 Watts to +33000 (and less if more power goes into grid). So the Auto Mode of the EVCS dont work anymore.
The solution is to change the communication from Modbus to MQTT. That feature is just available in the beta Firmware.
Thats why i am asking if someone can help to get my other 9 EVCS also to the beta channel.
What FW do you have installed?
I thought that issue has been fixed a while ago.
There is a link to beta FW in this document:
Thats the reason why i needed the Beta Firmware.
In this Document there is a link to the Beta Firmware. Thank you so much AhtiH !!
