EVCS: Switch between 1 and 3 phases
I have a 3x400V+N installation. I would like to be able to charge 1 phase or 3 phase depending on the need and available solar.
Could I add a contactors before the EVCS that turns on/off phases 2 and 3? Then depending on the need the EVCS will be powered with one phase or 3 phases.
If needed, I can make sure I stop the charging session between switching from 1 to 3 phases or other way around.
I understand I would need to write the logic myself in Node-RED.
Is this a viable setup?
Wow, this is awesome! I was not expecting this. Have to get an NS charger now.
On both NS and screen version it works
