EVCS source of Modbus TCP Server error
Running
Venus OS Large 3.70~74
EM24 Ethernet
EVCS v2.05/5.2
The Modbus communication works but I see a lot of errors (1 per second) in the Modbus Server window in the GX device.
ERROR “Error processing function code 3…. etc. The source mentioned in the error message is the EVCS (192.168.100.83)
Attached a short video showing the errors
Try changing the request to function code 4?
Sometimes there is a confusion between “holding registers” and “input registers” Some devices are sensitive, some are indifferent. Depends on the implementation.
