I am trying to use the EVCS scheduler for overnight charging. Typically the planner only works from 00:00 until 23:59.
This means I am putting additional strain on all electric components as well as the charger in the car as all power is gone for 1 minute and directly back online.
Is there a way to avoid this and make a real 24 hour schedule instead of 23 hours and 59 minutes versions.
Heelo @JasperR. Thanks for reporting.
Indeed, seems some issues in VC application. It is not allowing to create scenes that is crossing the midnight. It will be fixed.
In the same time you can try to create scenes thru web interface. You should be abble to start for example at 19:00 and stop at 02:00.
