I’m seeing a very frustrating issue with my Victron EV Charging Station in Auto mode and I’m trying to understand whether this is a configuration problem, a metering/reporting problem, or a charger/communication fault.
Setup
3-phase setup (MultiPlus-II 48/6k5/100-50, firmware version: 2602560)
EV charger in Auto mode (firmware version: v2.07)
Solar production yesterday was very good, for sure that was not the problem
Plenty of sun during the day, so there should have been enough excess solar available
What happened
The car stayed plugged in and “charging” for almost the whole day.
VRM showed that around 35 kWh had been charged during the session, so at first glance everything looked normal and there were no obvious errors.
However, the car itself only took around 2 kWh.
Later, I exported a VRM report and it showed that about 86% of yesterday’s EV charge came from the grid, which makes even less sense because solar production was strong and the charger was in Auto mode.
So the worst part is:
the system seems to have imported a lot from the grid,
the car did not actually charge properly,
and there were no clear errors shown in the app.
Additional symptom
The EV charger screen also looks corrupted, with vertical lines and the display becoming unreadable.
Because of that, I no longer trust the local screen to show the real charging state or any warnings correctly.
After a restart, the screen is back to normal.
What I want to understand
Could this be a CP/control pilot communication issue between the charger and the car?
Could the EVCS think it is charging while the car is not actually accepting power?
Could this be a VRM/EVCS metering or reporting issue?
Could Auto mode be incorrectly taking power from the grid even when there is enough PV?
Is the corrupted display a sign of a broader EVCS hardware fault?
Questions
Has anyone seen a case where VRM reports significant charged energy, but the car receives almost nothing?
Has anyone seen Auto mode import heavily from the grid even with strong solar available?
Can a CP/handshake issue cause the charger to appear active without actually delivering useful energy to the car?
Could the broken screen be related to the charging/control issue, or is it likely a separate hardware problem?
What logs, screenshots, or diagnostics should I collect next from VRM / GX / EVCS to narrow this down?
At this point, my main concern is not just bad charging performance, but the fact that the system seems to have pulled power from the grid without actually charging the car, which is obviously not what Auto mode should be doing.
Any guidance would be appreciated.
