I do not understand what to do and why, but all measurements are right now measured correctly
I have only 1phase system
on the next 2 phases there isn’t any solar production
Hi Alex.
So, auto-mode can work without the ‘feed-in’ feature, and it can wake up the MPPTs for EV charging.
I propose the following:
Configure your system without considering EVCS. ‘feed-in’ disable, ESS, etc.
Reset all EVCS settings to default, as I can understand you modified some internal settings related to auto mode. You can use ‘Keep wifi and access settings’ to simplify things.
Disable ‘Allow battery/grid power for auto mode’ or reduce ‘Battery/grid power timeout’ to avoid charging EV from the battery\grid.
Do not use ’ Allow low excess solar power for auto mode’. Seems you don’t need it.
I think that auto-mode will work with such a configuration.
If you see any problems - ping me here, I will check the behavior(but before modifications of any internal settings).
Right now it looks like a problem is solved.
Internal change was necessary.
The main value that was changed:
‘Battery powered’. Grid power for ‘feed in’ detection. register 5091 to -10000 to not detect ‘feed-in’ on my system.
Thank you @Nicolas for your help
maybe I have the same problem. " I have a new EVCS, works ok manual and programed, But in auto mode, says" Waiting for sun" when battery is 100% and system is sending solar surplus to grid (2.5k)
This is a standar solution? I need to make this change in my EVCS?
Hi @Viosmo. Which FW version do you have?
Does your system have more surplus power than 2.5k?
Seems your EV charging by 3phase and need at least (6A*230v)x3 = 4140w.
When the battery is full, does the SoC show as 100%?
I have exactly the same issue.
In the morning, it is working. I plug the car in auto mode - When SoC goes above 90 = “start charging at backup battery SoC (%)”.
In the afternoon, when I plug the car when the SoC is already high = 99-100%, the message “Waiting for Sun” appear. The only solution is to reboot the EVCS for the auto mode to work.
