EVCS auto logon
How can I make my EVCS website always log in. Because it is very annoying from time to time (every other day) type in admin password. I only have access to evcs website from my home network.
There should be checkbox “remember me” :slight_smile:
Most browsers ask you to save the username and password for you.
Yeah, but that does not help. For example I have Opera and today selected my charging station tab, I had open yesterday before computer shutdown. And was given login screen like this:
Its different when you press logout (then username is also cleared)
And I have the same behaviour in my second computer chrome, also iPad and iPhone safari browsers.
It happens when I select the tab I had EVCS opened before some time (not determined how long) ago.
And yes I can in every browser select saved password and log in but how to avoid that?
Please let us disable the login page, the same as the cerbo etc that have no logins.
hmm, is that a good idea?
Why does the cerbo not have a login? is that a good idea?
I can connect to the cerbo with no login and control the EVCS. Maybe the admin settings should be behind an admin login, but i see no reason why the main page should be. If someone is on the local lan that shouldn’t be then you have bigger problems.
