EV Station doesn‘t switch from manuell mode to time mode
Hi, if I try to switch from manuell mode to time mode it switches automatically back to manuell mode.
EV Station with Display rectangular.
BR Falk
@falk82 i think you need a time table first for scheduler charging - then it works!
Ok thank you I will try it and send you Feedback.
Hi, I checked the slides but I there is no silde „scheduler“. See picture below
There is no slide „scheduler“…
@falk82 your are at the latest version of the firmware? V1.30?
You have a very old firmware installed.
You first should update that.
Hi Mr. Lange, where I can Download the firmware file?
BR Falk
https://www.victronenergy.com/media/pg/EV_Charging_Station_NS/en/setup,-configuration---operation.html#UUID-8894ba93-60e5-4aa5-8725-3581fd51eefc
Thank you :grinning:
Hi all, after Update to Firmware 1.30 the schedule slide is visible and the cerbo switches to timeplan. Tank you for your help.
