EV Charging station dropping from WiFi when charging completes
I have a Cerbo GX running v 3.66 and an EV Charging station NS running the latest release. I am charging a BYD Dolphin Surf.
The Charging Station NS drops from Wifi every time the charging cycle finish and needs to be reset from the circuit breaker to get it working again. The wifi signal strength is a healthy -51dBm connecting to a Ubiquity Unify AP a few meters away from the charging station.
The charging station is connected to AC IN on a Victron Multiplus ii.
Any advice?
My charger NS keep wifi but drop connection with cerbo. I have to scan for modbus devices manually. Then appear but after a while lost again.
Did you try switching of bluetooth in the charger settings?
