Ev charger software and connection
Hi there,
I have a victron ess system and it is controlled by Cerbo gx, no issues working perfectly.
Last week i up graded the software /gui.
Since then i purchased a victron ev charger and for love non money, i cannot get it to see the cerbo. I think it is due to the software on the ev charger…
Any suggestions
I presume the EV charger is Victron as well, correct?
If yes, are both on the same Wi-Fi network?
can you post a picture with the configuration page on the EVCS?
Can you tell me the portal ID of your system, so I can take a look?
Lucian
Hi Lucian,
Thanking you for reaching out.
The firmware version of the EV charger is v1.23/4.2
The firmware of the Cerbo is v3.52 2
My vrm ID is
I have reverted back the EV to a standalone, so I can charge the vehicle, but it would not charge due to a SOC issue…
Can I arrange a call with you for later
Best Regards,
James M O’Neill MSc,MPM PMP MBA
M +353-(0)87 2290696 | jascdoneill@gmail.com
Please update the EVCS fw to the latest version, it is very old. And, we can have a look if necessary.
Hi Lucina,
Great, I have updated the EVCS firmware and now, it can see/talk to the Cerbo GX.
Another, question
How do I get to see the EVCS on my dashboard,
Currently on the vrm dash board, I see the following
Does it take a while to transfer across
I wish to be able to control/schedule the EVCS from the VRM
Thanks in advance,
Best Regards,
Good, do you see the EVCS on the GX interface?
If yes, just wait, it should appear in VRM.
Hi Lucian,
I think, everything is now working fine….
Thanking you,
I will be getting a 2nd Victron EV charger in a few weeks, I might need your help again,
Best Regards,
Hi, perfect, I’m glad everything works
