EV charger not resuming charging
you can set the startup behaviour in the app
that can do the job. You can control it with node red from the GX device. And the trigger can be the state of the EVCS? Like when charging is in starting mode? to open that relay for 1 sec
but if there is 230V on the output of existing relay, which is prepared for v2, why not use it ?
send me 1s long signal on that free existing relay and I’m done
yes. that Node Red is a solution, I was actually thinking to use Home assistant, I’m not very proficient in node red
home assistant and also openhab, both are working with shelly
but I prefer, that EVCS SW will control this relay, for best sync.
What’s about other not used connectors?
Most of them are used for other applications, as you can see on the labels.
The second AC relay can be used for 1P-3P switching.
So sorry, but adding this on current hardware is complicated, and we prefer to focus on releasing the new one.
ok, then shelly wifi relay must help :slight_smile:
when new version is planned for release ? I think I will buy one, if all functions are implemented
I can say more than this year :slight_smile:
ok, thank you.
Regarding timing. When must be CP signal disconnected ?
Is enough when status will change to 2-charging ?
edit:
oh sorry:
21 - start charging ??
You can try, i’m not sure, also depends on the car. How fast it goes to sleep? If it takes one hour, You can do something like this - if auto mode (I presume that’s what you need) and if waiting for sun or low SOC, turn relay off for 1 sec, then on, every 50 min
But you will have to figure it out, it’s just a suggestion.
I think car goes into sleep very fast - 30sec, max 1minute. So I think I must disconnect CP nearly before, when auto mode wants start
It should take longer than 1 min, try it
are you able tell me which setup is valid for auto mode and which for manual mode ? :
and what doing what ?
specially I’m not sure with :
Stop charging at backup battery SoC, if Off Grid (%): - is it only for manual ?
Allow battery/grid power for auto mode: - when I enabled, auto mode drain my battery
Allow low excess solar power for auto mode: - not sure
Battery/grid power timeout (min): - this mean how long auto mode can use a battery/grid ?
Backup battery emulation: - don’t know, always disabled
edit:
switch is ready in openhab
next tests tomorrow
perfect!
btw, you can do something else in there, if charged state is reported by the EVCS, you can switch it to manual, trigger your CP relay, put it back in auto
But you’ll have to add some kind of protection for when the vehicle is really charged.
first of all I will try trigger a CP relay on the state 21 - start charging. We will see. It’s easiest way.
Protection for what? I’m not following.
If the car is charged, the car BMS won’t overcharge the battery.
Protection for never ending cycling. If relay will triger on the EVCS status “charged”, problem started when battery is really charged. Relay will trigger, but EVCS will report that battery is charged and relay will trigger again and again and again
