EV charger and Octopus Intelligent Go compatibility
I’ve just purchased an E-Niro, so will need an EV charger, as I have a Victron System it would seem sensible to use the Victron EV charger.
What is the likelihood of Victron EV charger becoming compatible with Octopus Intelligent Go?
The unit rate is a bit cheaper on Go, and you can get additional cheap slots when Octopus decide, but it requires a compatible charger or car (I don’t think the E-Niro is compatible).
Came here for exactly the same question. I assume some API integration is required.
The general consensus elsewhere was that it would be a very long time before it was supported, if at all. Octopus tend to focus on the more popular mainstream chargers.
I ended up going with a Zappi, although I’m not very impressed with it, it has an awful lot of “features” I just don’t need, which complicates it. But I have got it working how I want, and my Node Red routines kick in when a IOG slot is given outside the off peak hours, so house batteries charge, and don’t discharge into the car.
I discovered recently that Victron have an EVSE with a published modbus register list, which makes this the only EVSE you can can buy, apart from openEVSE, with (fully automatable) local control (SFAIK - and I did ask about 30 manufacturers if they supported local control a couple of years ago - half of whom didn’t understand the question, the rest said ‘we have an app’, almost all of which actually worked through a remote server, and all of which were proprietary). So I was very excited about this.
But then I discovered that Victron is not on the list of about 50 manufacturers deemed compatible with Octopus Intelligent Go (OIG).
Octopus told me that they work with manufacturers to check devices work nicely with the API, but there are plenty of devices on the list which are not very ‘smart’ at all, and do not talk to the API - they are just capable of scheduled charging, which appears to be the minimum requirement for listing. Octopus Intelligent Go Compatible EV Chargers | Evergy which includes ‘Hypervolt Home 3’, Zappi, Easee One, Andersen Quartz, all of which do not talk to the API, but just allow scheduled charging or the tariff profile to be statically programmed.
Also on the list are “No charger (3-pin plug)” and “No charger (commando plug)” neither of which are talking to any API either, and demonstrating that the bar is very low.
I see on another thread ( Is Victron intending to add OCPP 2.x protocol support to the EV chargers? ) discussion of adding OCPP (which would be great), but it really should be possible to get on the list without doing all that work - that’s the ‘2nd level’ (API integration). ‘1st level’ (basic scheduling), ought to be easy to demonstrate. Being on the list is the crucial step from the point of view of the EVSE owner wanting to get the benefit of OIG: 5 hours of very cheap overnight electricity (IOG has Octopus’s lowest overnight rate).
I pressed for details of the minimum requirements, but was fobbed off with “There isn’t a link or way to make a charger work with Intelligent Go, the team responsible for updating the list will work with the individual companies and test to make sure that they are compatible. Unfortunately we have no way to influence this, they are constantly reviewing and updating the list.”
So has Victron had any contact with the Octopus EVSE team, to demonstrate that the charger is very capable of scheduled charging (and find out exactly what would be needed for API integration)? Has it in fact been determined that it does not qualify for some reason?
The chargers are amazing value (even after adding the Type-B RCD and either rod or PEN-fault device required in the UK) given the published modbusTCP details, but not being able to get on IOG is a big disincentive in the UK as is has the cheapest leccy of all their tariffs.
In the meantime, for anyone who understands why local control matters, and can’t wait for this issue to get solved, you can install an OpenEVSE EVSE, which is on the IOG list as ‘Openenergymonitor EV charger’. (bit confusing as they are the importer, not the manufacturer, but once you know, it’s OK). It has the same features as Victron of local control (HTTP and MQTT), needing external RCD and PEN-fault device/earth rod and being relatively cheap.
Had it been IOG compatible I would have bought one, but I ended up with a Zappi, which I’m not very impressed with. The website is slow, and the app’s not very intuitive, and of course it’s expensive.
But to be honest, once set up with IOG I don’t need to do anything apart from plug it in, I don’t need to control it although it would have been far better to have it within the VRM, but I’ve added it to HA via a Shelly Energy Meter, so I use that to see what powers been consumed.
@Lpopescu
Lucian, can you please comment as to if you have been talking to Octopus Energy UK re enabling the EVCS products to become compatible with their smart Intelligent Octopus Go tariff.
As others have mentioned there is an extensive list of currently compatible chargers for this tariff, but no Victron.
I took am looking to switch to using IOG when winter arrives to get the cheapest prices.
I have already invested in adding an EVCS NS to our existing MP2 based system and it integrates nicely with our solar and battery system.
We really could do with IOG comparability being added too please?
Hi, I’m not in contact with Octopus Energy UK, not sure if the products are compatible or not.
Hi @Lpopescu
This morning I telephoned Octopus Energy customer services to request what is the process required to get Victron Energy EVCS units added to the compatability list for the Octopus Intelligent Go tariff.
Unfortunately I received a rather disappointing answer - I was told that they will only look adding a charger to their compatibility list if they receive a high demand requesting so on their website.
So, with this in mind I might post a link to the Octopus EV charger request page on the Victron FB group requesting that Victron customers request Victron EVCS compartbility to Octopus Energy.
Hopefully, if enough people do so, it might trigger Octopus to start their onboarding process.
Is this idea OK with you?
Thanks
Jim
Sure, no problem! And I’m available for them if they need extra support.
Lucian
Can you post the link here too please? I don’t use Facebook.
Hi Paul,
The link is below, but my idea is not as straightforward as I first thought……
You have to login with your Octopus account number
Thanks, I’ve filled it in.
Thanks for that Jim. I got the impression that Octopus expected the manufacturer to get in touch and they would work with them to confirm compatibility, but possibly this ‘sufficient demand’ step is also required and they just forgot to explain it.
Given that all that is required for level one is the ability to set scheduled charging, the EVSE is almost certainly already compatible, and Victron doesn’t need to do any actual work. So if Lucien gave them a call it might be straightforward to just get it done?
In the meantime I have filled in the form (had to make up a car as I don’t actually have one yet - that is pending choices about EVSEs).
I want to pass the link on to someone else, but I can’t see how to extract it from this forum, and I failed to find it again on Octopus’s site. Can you post it just as text too, or a standard cickable/copyable link rather than a live-rendered one?
I can’t work it out either, but you can do the next best thing and send them a link to the post above (no need to be signed in for them to use the form), click the little chain symbol in the bottom of the post and send them that.
Hi @Lpopescu
Revisiting the topic of Victron EVCS chargers being compatible with UK smart energy tariffs.
It seems like you guys need to approach Octopus Energy and the other main UK energy providers directly to get your chargers compatible with the energy providers smart tariffs.
Please find attached below the current, very extensive list of existing EV charger brands that are currently compatible with the Octopus Energy Intelligent Smart tariffs and you guys are still very much not on the list.
This extensive list is also very similar if I go and look on the the British Gas, Eon and the other main UK energy supplier websites. Victron doesn’t appear on any.
As much as I love the EVCS integration in our home Victron based ESS, we are losing money having to pay higher EV charging tariffs, not having the EVCS as being certified compatible. The difference is between 6.5p per kWh to 9p per kWh and also not automated. We are also subject to only 5 hours low rate overnight period, compared to 6 hours on the Intelligent smart tariff.
So much so, we are contemplating removing the EVCS and replacing it with one of the many compatible chargers, even though we will lose VRM integration which will be very disappointing and costly to do.
Please please make contact with the UK energy companies to discuss getting your chargers compatible with their smart tariffs.
Hi, do you know what that means? what is necesary from our side to be on that list? If any of you can give me some extra details, it would be very helpful.
Thanks!
PS if you remove the charger. I would recommend HyperVolt. I’ve got an Indra had an Andersen but HyperVolt charger is better IMHO
I do believe it would have to have Octopuses Spin Off companies software by the name of Kraken . Hope that helps
Send me a private message, and I’ll give you an email address of someone at Octopus Energy that will be able to help.
I chose a Zappi, as the Victron charger isn’t compatible with Intelligent Octopus Go
Hi @Lpopescu ,
I’ve done some Googling, a good starting contact might be Phil Steele at Octopus Energy, he’s their Future Technologies expert and I would think a good initial contact to ask what is required to get your EV chargers compatible for Octopus Energy
His email address is philip.steele@octopus.energy.
According to the screenshot attached, you should also be able to reach him via X and LinkedIn too.
Hope this helps
I don’t know who to contact for the other UK energy supplies, but starting with Octopus Energy will be good as they are now the UK’s largest energy provider.
