Good afternoon,
On 08-01-2025 at around 1230 till 1330 (Portugal) I got various alarms saying bus failure 3 and a little later bus failure 14, leading to 3 times an automatic restart of the system.
Upon investigation we found (my neighbour was there during the 3rd black-out) that only the 3 yellow bulk leds where on from all 3 inverters, meaning grid high voltage, but no alarm was registered, nor in bus nor the Cerbo or to VRM (not possible) other than the high voltage alarms of these phases.
We found that the voltage must have passed the 270V on at least 2 phases.
E-mail service from VRM was stopped due to their ratelimiter of sending alarms as well.
The spikes were not registered in VRM, but just showing 261 and 263V, see below.
The inverters started up within 10-15 seconds the first 2 times, but the 3rd time can be clearly seen in the graph as it stayed off for 16 minutes.
The issue is, that at the time this happened the inverters were not taking power from the grid, they are always connected and the grid is our emergency generator.
Why does the inverter(s) switches off when the grid voltage is high (but not used) instead of just switch the power off internally to the control board only and continue on its secondary DC power supply, like in island mode without a grid.
Are there any such issues registered in our community, as lately there was a Dutch camping owner who changed to Victron, as he burned his inverters and some PV panels before due to the ever increasing grid voltage in Europe.
That would mean, that’s not the solution, as with high voltage it switches off the same…
Specially ESS installations and other grid connected will suffer a lot from this as well…
In VE-config the maximum setting is 270V, so above, no inverter working…
I will now install a 4-pole 40A relay and an over/under-voltage switch to just switch the grid completely off above 250-255V (nor in VE-config, nor in the Cerbo you can program a relay to do that) to solve this temporarily or maybe permanent.
The grid supplier is notified, but, as usual, they are slower than…and nothing will be done about it, see below last half year in detail mode, EDP is the local supplier there.
Regards, Jeroen.
