Ethernet and modbus tcp simultaneously with a switch Multiplus II GX 48/5000/70
I am planning on using modbus tcp on my Multiplus II GX 48/5000/70.
As there is only one ethernet port, can I use a switch to connect the multiplus to my house using ethernet network and to an ESP32 through modpus TCP at the same time ?
Yes you can. if you intend to use the wifi at the same time, restrictions apply. Make sure to set which interface is internet facing else you will have connectivity issues.
