ET112 as separate AC consumption
I have a system based on Victron SmartSolar MPPT 100/50, Cerbo GX, and several other Victron devices. The system operates in full off-grid mode (without connection to the power grid).
I do not have a Victron converter – I use a different brand.
I purchased an ET112 meter and would like to configure it in VRM so that it shows separate AC consumption (separate AC load circuit).
I have a problem with this – I am not sure:
How to correctly set up the ET112 in Cerbo GX / VRM (which role to select – AC Load, Grid, Generator, etc.) so that it shows independent consumption?
There are several colored wires in the meter – please advise which wires should be connected to which terminal in the ET112 (RS485) to correctly measure consumption in an off-grid system?
In the case of a system without a Victron converter, are there any limitations to the functionality of the ET112 in VRM?
