Hi everyone,
I have a Pylontech US5000 battery connected to a Victron Multiplus 2 GX. My system is set up according to this manual [Victron & Pylontech]. Here’s my current configuration:
- AC Connections: One grid AC input and one AC output.
- Battery Connection: Linked to the inverter via the original CAN VE cable.
I’ve enabled the ESS Assistant in “Keep Battery Charged” mode. The grid metering is set to inverter/charger, and the grid setpoint is at 0 W. My goal is to use the battery like a UPS—only activating it when the grid is unavailable.
According to the Victron manuals, my configuration should be correct. However, I’m experiencing an issue where the battery is constantly discharging and charging whenever the grid is available.
Thats all time grid is available and can be transfered on ac loads
Firmware is updated
Can anyone help me troubleshoot this or suggest changes to make the battery function as intended?
Thanks in advance!
