ESS: MultiPlus does not increase battery charge despite spare CCL – export on other phases
Post text:
Hello everyone,
I have a technical question regarding ESS behaviour with a single-phase MultiPlus on a three-phase grid connection.
Setup:
  • MultiPlus-II 48/3000/35-32 (single-phase on L1)
  • ESS enabled
  • 3-phase grid connection with grid meter
  • PV inverter feeding 3-phase
  • Battery connected via CAN-bus BMS
    • CCL = 30 A
    • CVL = 50.2 V
  • Multi in Bulk, no voltage limit active
  • AC input current limit = 15 A
Observation:
  • Battery charges steadily at approx. 25 A @ ~45 V (~1.1 kW)
  • At the same time 300–600 W are exported to the grid
  • There is still CCL headroom up to 30 A
Question:
Why does the MultiPlus not further increase its charging power on L1 to absorb the export on L2/L3?
From my understanding, the Multi should be able to increase charging further as long as:
  • CCL is not reached
  • no CVL is active
  • AC input current limit is not reached
So my questions are:
  • Is there an internal ESS control limit that prevents additional “artificial” grid import on one phase?
  • Or is there a separate charger current limit inside the Multi that applies independently of the BMS CCL?
Any technical explanation or pointer to relevant documentation would be highly appreciated.
Best regards
Paul
It might be phase compensation.
Is the pv inverter controlled by the victron?
Thank you for your answer.
OK, I will have a look at this. Is there something I can change to “optimize” it?
No, its a standalone Growatt MID 20K.
I am not sure. I have not done a set up like yours.
On the phase compensation though in a three phase set up, depending one your local regulations if there are any, sometimes set to individual phase halps with power control on each individual phase rather than is being a sum of them.
First you should check, what kind of billing method your grid-provider is using:
  • If you are billed per phase (Sometimes called Gross-Metering) trying to charge more on phase 1, because you feedin on 2 and 3 will make you pay for the electricity pulled from grid on phase 1. Then, you should set the Multiphase-Regulation to “Individual” to avoid this.
  • If you are billed in total (Saldating Metering) then you only pay for the “total” that apparently is pulled from Grid. In that case, you can set Multiphase-Regulation to “Total of all phases” and the Multi will then pull some hundred watts from grid on L1 to charge, as long as it can be compensated on L2 and L3 to have a “0 total”.
For the later setup, make sure you use a grid meter supporting saldating-measurements, else the figures in VRM don’t fit reality well.
Also, with a supported BMS being present and reporting a CVL/CCL, you should enable DVCC and set the controlling BMS to your BMS (Most the time “auto” will do that right). The inverter then should just state “External Control” rather than bulk / absorb / etc., if i’m not mistaken.
Thanks for the feedback.
Just to clarify my setup:
  • I am using an EM540 grid meter
    → the meter is saldating / summing all phases (Total of all phases)
  • ESS multi-phase regulation is set to “Total of all phases”
  • DVCC is enabled
  • The BMS is connected via CAN and used as the controlling BMS
    (CVL/CCL are provided by the BMS, inverter is under external control)
Grid billing is also saldating (which is the common case here).
From my understanding, this should allow the Multi to increase grid import on L1, as long as it is compensated by feed-in on L2/L3, keeping the total close to zero.
This is exactly what the system does – but only up to about 25 A battery charge current, even though the BMS allows 30 A CCL and no CVL is active.
So my remaining questions are:
  • Is there an internal charger current limit inside the Multi that applies independently of the BMS CCL?
  • Or is there an additional ESS control limit that prevents further increasing charge power on a single phase, even when saldating is active?
If there is a documented limitation or a relevant setting, I would appreciate a pointer.
You can in settings in the base program limit it -yes.
Possibly the limit charge current is set in dvcc? It can ve set separately to the battery request.
Those would be the two things to check.
Also compare the battery monitors and which you are displaying. It may be well possible that the battery is already reporting 30A, but the multiplus concludes 25A and that is your current display battery monitor.
And finally, the limit set by the battery is also not a decimal precision thing. It may allow / request 25A even if it’s actual capability is somewhere between 0 and 25A.
Or let’s phrase it like that: it’s a limit not to exceed, not a current request. The actual current flowing is depending on the difference between the battery voltage and the applied chargevoltage, which is suspect to be limited as well through differerent mechanics.
What batteries are you using
