ESS does not honor Minimum SOC
I do! I’ve switched it to “Above minimum SOC only” now, I hope this will help.
Is there a way to manually turn this bridge off, or otherwise prevent ESS from consuming energy from the battery? This would be a workaround for my other problem ( Multiplus feeds in even though feed-in is disabled ) where ESS depletes my battery in order to feed into the grid.
The system will however go into the recharge state if the soc drops by more than 5% below the minsoc and charge it back up to minsoc, so this will not deplete the battery entirely
I have not found this to be the case. But perhaps I wasn’t brave enough to wait longer.
