I have a Multiplus, a battery with a SmartShunt, and a Victron MPPT all connected to a Cerbo GX. I set up ESS to my desired settings, but it does not behave according to my settings.
I have set “minium SoC” at several different levels and observed behavior. The ESS is set to “Optimized with battery life”. Whether I have minimum SoC set to 90% or 50%, the actual battery percentage falls to ~75% between absorption cycles (which happen once a week).
When the SoC falls below the set level, the “SoC is low” and “Battery life is active” in the details, but the battery continues to drain and wattage from the AC input does not increase to compensate. It is typically in this state for 3-4 days until the next absorption.
Every single part of this system is running the latest available firmware.
Again, right now I have “Minimum SOC Unless grid fails” set to 85% and the current SoC is 79% and falling. If mains power were to fail at the wrong time, I could be down 25% of my battery capacity.
