Hello a
Today I tried to add the ESS assistant, I configured it but it doesn’t work, I see it in the cerbo menu, I set the bellow value to charge the battery and switch to the grid and nothing, I limit the power of the inverter but it doesn’t switch to the grid for the difference. Where am I wrong? Grid code is set to Romania.
Cerbo does not have an ESS assistant.
You have to start ESS assiatant via VEConfigure on a PC with a supported device like the multiplus, There is no way to start the ESS assistant via Remote console.
For further details see: 2. Introduction and requirements
You have two options to start and configure the ESS assistant:
-1- Direct Connect via MK to USB device to your supported device like a multiplus
-2- Remote configure via the VRM portal: VRM: Remote VEConfigure [Victron Energy]
After you have configured the ESS assistant on your Multiplus, you can configure options on the Cerbo menu via the remote console on Settings/ESS and Settings/DVCC.
Thank you for the answer. I’ve used the mk3 to add the assistant, I didnt had any problem installing the assistant. The problem was that I had to wait for 15 minutes to be syncronised with the grid.
All the best.
Sort of old thread but might help others in same situation.
I ran into the same “issue”, of 15 minutes grid reconnect delay.
For Romania grid code settings, there is a reconnect time of 900 seconds. That time is adjustable in the VE Configure 3 - Grid - Romania grid code settings - Reconnection time
