Error #67 on 3x MPPT 450/100 (Pylontech batteries + LV-Hub) – production halted
Hello everyone,
​I’m seeking your help after a solar generation issue brought my installation to a standstill.
​System configuration:
  • ​Charge controllers: 3 x SmartSolar MPPT 450/100
  • ​Battery bank: Pylontech batteries managed by an LV-Hub
  • ​Communication: BMS / CAN data cable connected to the GX system
​The problem:
My three MPPT 450/100 chargers are showing error #67 - No BMS (or BMS connection lost). As a result, the charge controllers are stopping charging as a safety precaution, and solar generation has come to a complete halt.
Even though it is plugged together with the cable, the hub is not communicating with the system.
Does the pylontec appear in the device list or does it say device disconnected?
Are the 450 mppts connected with ve direct or ve can?
Thanks LX! I checked the list of devices in the app:
  1. ​Pylontech status: The battery monitor (Pylontech BMS) appears in red and shows “Last seen 3 days ago”. So communication with the BMS has been interrupted for 3 days.
  2. ​MPPT connection: All 3 MPPT 450/100 units are connected via VE.Can and are communicating properly with the GX (last seen 3 minutes ago).
​Since the LV-Hub is switched on, but communication has been down for 3 days, do you think this is a problem with the BMS/CAN cable (between the LV-Hub and Cerbo GX), or an incorrect CAN configuration/port on the GX? It’s been working fine for almost 7 years.
I doubt it will be configuration since it is not a new installation.
Restoration of communication depends on the cables used. but check for corrosion or rodent damage, that would be my best guess after a period of time has passed.
Sometimes the hub needs s a restart.
Thanks, LX, your theory makes a lot of sense! Since the installation had been working perfectly until now, a physical cable fault or a hub lock-up is indeed the most likely explanation.
I’ll carry out these checks on site:
Completely reboot the LV-Hub.
Inspect the BMS/CAN cable from end to end (physical condition, corrosion on the RJ45 connectors, signs of rodent damage).
Test with another BMS cable if necessary.
I’ll let you know the results as soon as these checks have been completed.
I’ve been at the site since last night. As a precaution, I brought the Type A CAN cable and replaced it, but the battery still hasn’t appeared in the device list.
Here’s what I’ve noticed: the status light doesn’t come on?
Can anyone help me?
Hello everyone,
I’m just following up on my previous message, as I’m not sure whether it was received or read. Unfortunately, I haven’t had any response since yesterday.
So I’m wondering whether it was passed on, or whether there is a usual waiting period before receiving a reply.
Sorry for following up, and thank you in advance for your understanding.
I’m new to this Forum group.
Hi and welcome.
Just to set the correct expectation, there is no guarantee of a reply, the community isn’t an official support channel and answers come from members with widely differing experience.
Have a read of our community guidelines, it contains an official link to victron support which is provided by your supplier.
In the meantime do some searching there almost always is relevant topics already and I am sure someone will give some advice.
Hello, I’ve never installed an LV Hub before. I’m wondering, though, why you have an LV Hub with only one battery bank connected to it. Do none of the Pylontech modules have a CAN bus connection?
If they do, you could try connecting a master unit from your battery bank directly to the GX and perhaps narrow down the cause of the error.
I have found a good old power down of everything and reswitch on helps.
Bit more thorough than this.
And those hubs are a pain.
You are right the status light should be doing something in either green or red.
Maybe check if no one has changed the port speed for the BMS connection?
How many batteries are there and what model are they?
You can use the @my user name . I didn’t see your reply.
Hi! The LV-Hub is essential in my case because my setup consists of several Pylontech US3000C batteries connected in parallel. It acts as an essential hub for centralising and managing CAN communication with the Cerbo GX.
So there’s no communication at all, which has me wondering what the cause might be…
You can connect up to 16 modules in a group via RS485. The master is connected to the GX via CAN. You need the LV Hub when you have several groups, each with up to 16 modules.
Do you have more than 16 modules?
