Erratic data display from CerboGX
I am getting an erratic data display on my touch screen connected to a cerbo gx. The data panels are predominantly blank then every 5-ish seconds, the correct data is shown for an instant then the boxes turn blank again. Data from bluetooth devices behaves normally. Settings and other panels also behave normally. The behavior was the same for both the new and classic UIs. Seems like the data cable to the quattro could be the culprit but its a bit of a mission to get to the quattro so wanted to see if it could be something else?
I wonder if you don’t have interference on your cables/wiring
Seems like something else is also wrong. The solar information is also disappearing and that is a totally different cable.
What firmware are you running there?
Maybe we need more details to help.
The Cerbo is at 3.54. The Quattro is at 552
All other devices are current.
