Does anyone know how to get Enphase in the VRM portal.
When I click on search for pv inverter VRM can’t find them.
Everything works fine and I am using a grid meter too measure the pv power.
I am just wondering if this is possible.
With a supported meter, and the meter role set correctly, it should appear as a tile on VRM.
iirc Enphase isn’t natively supported, so the system will only know it is there if you have a meter configured correctly.
Best to run through the PV inverter setup docs and the meter manual to find your bearings.
Thanks will keep looking ![]()
Don’t forget to configure the frequency shifting, either via ESS (if on-grid and using ESS) or the PV inverter assistant.
Have a start here:
https://professional.victronenergy.com/online-training/18/
Should equip you enough to be dangerous ![]()
Thanks !!! But already did that ![]()
I was just wondering if enphase an Victron are on the same page.
If you use fronius or ap systems you should get a small visual in your VRM screen (seen that somewhere)
Maybe in the future…….
The only ones with a native (modbus) integration are Fronius, and more recently SMA.
Others will not be seen, but their power recorded via the meter, which will be displayed as a PV inverter on VRM, when the role and location is set.
Beyond that, without writing your own drivers/integration, it will not be discovered on the GX like the other 2.
