Enphase modbus system not showed in VRM
Don’t send a mail (this never worked for me), open a chat conservation.
At the other side they don’t know what modbus is, give them the link to the paper.
And they also can’t explain why port 502 is closed,…
OK, thanks. I’ll share any updates when I have new information.
Same here (Netherlands). Tried all mentioned solutions you’ve all been sharing, but no success. Also a ticket to Enphase without response. My WiFi on the Envoy is not connected, only cable is active.
Would be nice if we could see and adjust the settings in the app, like SolarEdge.
I’ve had the same problem here since Thursday, May 28th at 9:45 PM.
On Friday, May 29th, I contacted Enphase technical support by phone to check the operation of the Modbus TCP. A problem was detected, but they couldn’t resolve it immediately.
On Monday, June 1st, I contacted Enphase technical support by phone again to ask for an update. They completely reinstalled the Modbus software for integration with the Victron:
However, no result. They promised to investigate what the problem is and inform me via email. I have not received a response to this yet.
I am going to call them again and present the information you shared. Thx.
To be continued.
I also have the same issue since end of May but didn’t had it integrated through the modbus TCP/Ip but via the scripting from mr Manuel. How did did you get that working?! I 've been the phone with Enphase manay times last year but ultimately they said that this wasw not available in the Netherlands.
Open an live chat:
Ask to open Modbus and refer to this Enphase document:
https://enphase.com/nl-nl/download/ac-coupling-victron-battery-inverters-using-modbus-tcpip
Did that last year only by phone, and also referred to the document. I’m at the point of ripping the whole Enphase crap out and replace it by Victron Mppt’s.
Yesterday I had a live chat with Enphase, they investigated in my installation and activated Modbus TCP (again?).
But this did not help yet, I now replied on their email:
To be clear, I’m on the Beta firmware for victron Venus OS 3.80~27.
are others on the stable version Venus OS 3.73?
Just to be sure that this is not something from Victron itself?
George
Don’t mail of call them, open a chat!
Mails never worked for me.
And you must have patience mine last chat took more than a hour.
I am still on the same firmware version. One that worked perfectly fine before. It is a total mess right now. Unreliable. Time to end it with Enohase.
What exactly was the issue? Why did it take a full hour?
Issue was that modbus TCP/IP was turned off or port 502 was closed.
Explaining this the other side took time, and after understanding they have to log in your system.
Tell them also the CT error is normal, elsewhere they want to fix that.
To not timeout the chat you have to write something every 1-2 minutes,…
I real don’t understand why turning on or off modbus is not an option you can toggle.
Hi there,
my Modbus TCP connection is working again.
they opened port 502, and I can see the production again in Victron VRM:
I will try to get them working on it intern, so that probably they can open the port 502 on all installations.
George
I contacted Enphase by chat today. They re-enabled the Modbus. Everything is working again. Thanks for the help.
great!
Same here in Spain…
Hi, I am from Spain. My issue started on 05/27/2026 (at approximately 7:00 PM). After calling and sending an initial email to soporte_es@enphaseenergy.com without receiving a response, I forwarded the same issue to support@enphaseenergy.com. They directed me to contact api@enphaseenergy.com, who were the last ones to reply to me on 06/09/2026, stating:
Thank you for your patience.
We would like to inform you that the incident has been escalated to the appropriate team for further investigation.
The corresponding team is currently reviewing the case and working to determine the root cause of the issue. As soon as we receive any updates or additional information from their investigation, we will keep you informed of the progress.
We apologize for any inconvenience this situation may have caused and appreciate your understanding while the investigation is ongoing.
Kind regards,
We will see how long it takes them to fix it.
Don’t mail (never worked for me) open a live chat.
Yet port 502 is still closed :man_shrugging: days later, and yes it used to work.
Open next live chat, that is the only thing that helps!
