Island operation / backup mode when grid voltage is too high
Hello, I can’t find anywhere, in so many words, whether a MultiPlus II automatically switches to UPS mode if the mains voltage is too high. I’m considering using a MultiPlus to achieve this. At the moment I have a (sometimes) working SolarEdge PV installation with an inverter. It shuts down when the mains voltage is too high — every day in my case! And according to Enexis, this will continue for another 10 years.
Does anyone know, or have any experience with this problem? Can I solve
that by following the Victron diagram? Will my house now be equipped with a UPS using this setup?
Kind regards,
RoelofS
Yes, that’s right. If you connect it like this, with your PV on the house side and the MultiPlus between the grid and your house.
Do bear in mind that when your battery is 90% full, the MultiPlus will increase the frequency so that your PV system stops producing as well, to prevent the battery from being overcharged. But if you install a large battery, you can of course neatly store all the solar power!
Of course, you can still use whatever you have stored in the battery! And you can potentially feed it back into the grid in the evening when the grid voltage drops again. If you use dynamic tariffs, you can even make some extra money from it.
George
And indeed, your MultiPlus automatically disconnects from the grid when the grid voltage gets too high, while you still have power from your PV system and inverter through your batteries.
You could also consider putting some of your panels on an MPPT; they’re more efficient and stay on for “longer”.
Overeeeg de Victron RS6000, daar sluit je rechtreeks de panelen op aan. Dan wordt de accu ook direkt met zonnestroom op geladen = minder energie verlies dan met een externe normale zonnepaneel inverter.
