Is any way to tell the DVCC to modulate the battery charging power at different temperatures? For example if temp is 5 Celsius the max charging amps will be 20A, so mppt and victron acin will modulate to this parameter. This could be a nice addition as BMS only allow on/off charge and LFPO cells can be charged at low temp but with caution, so limit the charge in the DVCC to, for example, 800W at 5 Celsius, 1000w at 6 Celsius or so could be a nice feature.
With “Battery Safety Controller” you can manipulate CCL and CVL from BMS to Venus OS.
If you have a way for the GX to read the temp then you can in node red limit or delimit in dvcc
yes, got JK BMS connected to the cerbo, who reads the BMS info directly. I suppose I will need to make my own programing like you said, as there is not direct option on venus OS. Thank you.
