Hi all.
I have an all-Victron system in my van, with a MlutiPlus II 12/120/2000, Lynx Smart BMS, Cerbo GX, and Smart Lithium batteries.
I turned DVCC on so I could set current and voltage limits while restoring the batteries, which were over discharged. Now that everything is back to normal, I went into the DVCC settings on the GX, set “controlling BMS” to None and then turned off DVCC. Then I went into the MultiPlus settings and chose “Restart VE.Bus system”.
However, the GX power flow display still shows the MultiPlus as “Ext. control”. I’m not sure what is controlling the charging at this point.
Any input is much appreciated.
