DVCC & Charger settings for LIONTRON LiFePO4 Speicher LX48-100
I installed an ESS with two LIONTRON LiFePO4 Speicher LX48-100 batteries in combination with:
  • Cerbo CX
  • MP2 5000
The problem is that I’m getting low voltage errors and assume that the typical Plyontech settings are not suitable for the Liontron batteries.
Can anyone post the DVCC / ESS assistant / Charger settings for these batteries?
I can’t find them anywhere on the internet and just the datasheet of the batteries doesn’t really help me.
I am also highly interested. I have the same issue.
Take care that your battery is a 16S battery (51.2V) and the usual Pylontech is a 15S battery (48V).
So, if you set the voltages as per Victron guide for Pylontechs, those voltages are too low for a 16S battery like yours, hence the low voltage alarms.
Usually you need to set them about 56.5V bulk/absorption and about 55.5V float.
Of course, depends a lot on your BMS settings, especially the balancing minimum voltage, therefore set the float a little bit above that.
