I’m about to wire our DIY campervan. I know the Victron must be configured though most example i’ve seen with the Victron are with 12V lifepo4 systems
This is from the battery manuals (230AH 12V):
Charging:
recommended charge current: 46A
max continuous charge current: 200A
recommneded charging 12V 14.6V (Lifepo4)
charge/boost voltage: 14.4 ± 0.2v
absorption voltage: 14.4+= 0.2v
Over Voltage Disconnect : 15v
Over Voltage Reconnect: 14.2V
Tail Current: 4.6A (0.02c)
Discharging:
Under Voltage Warn: 11.6V
under voltage Recover: 12V
low voltage disconnect: 10.8V
Low voltage Reconnect: 12.4V
I beleive i need to fill in the following values in the victron settings. I assume as i’m creating a 24V system i should simply multiply the values by 2 to get the proper values to fill in ?
dc input low-shutdown:
dic input low restart:
dc input low pre-alarm:
Charge current (anything up to 200A?): 120A?
I guess it make more sense to use something like 120A ?
Our cables are 2/0(221 Fareneight insulation) (on 24V) good safe for 200A.
But since we have an Shore Input braker of 15A that would mean max input of 60A ?
Charge Current: (below maximum charging rate)
Absorption Voltage:
Float Voltage:
Repeated Absorption Interval:
Maximum Absorption Time:
Repeated Absorption Time:
Temperature Compensation:
Charge Curve:
Found a thread of a lifepo4 settings from the manufacturer… but that is still 12v. So we should simply multiply it by 2 ?
(this was maybe not the same exact battery, it was a 100AH instead of the 230AH)
-High Voltage Disconnect: 15V
-Charge Limit Voltage: 14.6V
-Equalize Charge Voltage: 14V
-Boost Charge Voltage: 14.4V
-Float Charge Voltage: 13.8V
-Boost Charge Return Voltage:13.33V
-Over Discharge Return Voltage:11.8V
-Low Voltage Alarm:11.2V
-Over Discharge Voltage: 10.4V
-Discharge Limit Voltage: 10.4V
-Over Discharge Delay Time (seconds): 10s
-Equalize Charge Time (minutes):120mins
-Boost Charge Time (Minutes):270mins
-Equalize Charge Interval:180mins
-Temperature Compensation: 0
Any input would be appreciated
thank you.
