Duplicate VRM Instance numbers - any issues?
I noticed that I have two Bluetooth sensor devices with the same VRM instance number. VRM seems to be displaying the data from each as it should, but I am wondering if having the duplicate instance numbers will be problematic? One sensor is a Mopeka LPG Tank sensor, the other is a Ruuvi Temperature/Humidity/Pressure sensor. Thanks!
Hi see answer from the old community, answer is at the bottom of the thread.
VRM instance number duplicated?? - VictronEnergy
Awesome. Thank you!
