Does the little screw on the side of the Victron Smart 100/30 MPPT Solar Charge Controller need grounding to chassis?
Cheers all
Cheers all
4.4. Grounding
Battery grounding
The solar charger can be installed in a positive or in a negative grounded system.
Apply a single ground connection, preferably close to the battery, to prevent system issues or ground loops.
Chassis grounding (only for the 30A model)
A separate ground path for the chassis ground is permitted because the chassis is isolated from the positive and the negative terminals.
Thanks for your time ![]()
