Should the chassis of an MPPT 100/50 be grounded at the ground screw (A)?
The manual states the following:
Chassis grounding (only for the 30A model)
A separate ground path for the chassis ground is permitted because the chassis is isolated from the positive and the negative
terminals.
Should I read from that that on the 50A model (i.e. the MPPT 100/50) there is NO need to ground the chassis via the ground screw?
Thanks!
