Does the Multiplus 3k support the "power assist" function to the auxiliary AC output?
Hello, I am new to this community. I have recently purchased the Multiplus 3k and have a question on the auxiliary AC output. I understand that the auxiliary output only provides power when the unit is connected to shore power. I am planning to use this function for an AC circuit in my RV. My question is, does this auxiliary leg offer power assist? For example, if the shore power connection is limited to 10 amps but I need 14 amps to operate the AC unit. Thanks.
Yes it does because the second ac output is connected to the main ac output by a relay so the system does not differentiate, there is only 1 ac output control / current meter. See the schematics, I do not know if this is the exact model you have but they are similar in this respect.
