Hello all,
A question for the community about a MP system I am designing, specifically with regards to PowerAssist:
Looking at the documentation, I understand that only the L1 output of AC out 1 has the PowerAssist function.
Very conceptually, let’s say the generator is running and maxed out at 50A, and the system is perfectly balanced so each output (AC-out-1 L1 & L2, and AC-out-2 L1 & L2) are each drawing 12.5 amps.
Now all of a sudden, something else kicks on on L1, looking for another 10A. The PowerAssist will feed that additional 10A into AC-out-L1.
Assuming all of the above is true, what if the additional 10A is called for on AC-out-1 L2, or one of the AC-out-2 lines?
Will the system still PowerAssist 10A into AC-out-L1 so that the generator output can shift to satisfy the add’l 10A elsewhere?
With the introduction of the Victron equipment, I am looking to downsize my (old, broken) generator from 8kW to 6kW, and believe that should not pose any issues since I can pick up 3kVA with the PowerAssist. Would anyone counsel against the downsizing?
Thanks, Steve
