I have a MultiPlus-II PMP122505012 connected to a Digital Multi Control REC020005010 and I’m having a strange issue with the LEDs on the remote panel.
The MultiPlus itself seems to be working correctly, but the LEDs on the DMC don’t match what I see in VE.Configure.
For example, VE.Configure shows Mains On and Absorption, while on the REC020005010 I get Inverter On and Low Battery.
From what I can see on the Victron website, both REC020005010 and DMC000200010R are listed as compatible with MultiPlus-II. However, I noticed that the current datasheet of the PMP122505012 mentions the DMC000200010R.
So I’m wondering if the REC020005010 is actually compatible with this MultiPlus-II, or if I should use the DMC000200010R instead.
Has anyone seen this behaviour before? Could it simply be a configuration or connection issue, or is there something that needs to be changed/updated for the REC020005010?
I’ve attached a couple of pictures showing VE.Configure and the LEDs on the panel.
