I have the Multiplus Compact installed in my campervan. I cant get to the VE bus sockets without removing the unit from where its mounted which is a pain to do as the front panel screws are hidden.
I have the remote control panel fitted and would like to use this cable to access the settings to turn off the charger. But the unit will only turn on with this panel and the switches on the front are dead. I assume its because the dip switches have to be set to use this panel.
Any way around this other than removing the unit and using another cable?
Trouble is that when I disconnect the cable, the Multiplus qont turn on by the switch on the unit. I think the dip switch has to be set for the DMC to work. I dont know if it will cause damage if I turn on the Multiplus with the DMC first the disconnect the cable to then connect to my laptop via the usb interface dongle
Not sure if this works in combination with the DMC:
You could connect this RJ45 splitter to the DMC, that way you have an additional RJ45 port to connect the MK3.
