Device in Cerbo which I cannot remove
My Enphase PV installation is connected to the cerbo. I see solar energy coming in with the remote console and on the VRM portal. However, it still has a device which I cannot remove. It feels like it has configured some device id under the hood:
These are my actual PV inverters:
And for some reason Settings>Integrations>PV Inverters>Inverters also shows: (Huis) which needs to be removed.
When I click on Huis:
I don’t see device, and I don’t see it in the device list…
How can I remove the PV Inverter Huis?
It does show these “devices” in the remote console:
But no Huis entry there…
When I change these inverters to Phase1 they become visible instantly in the VRM device list.
Same issue as: PV inverters disappear from VRM device list after changing phase (L1 → L3, SMA SunSpec) ?
I indeed tried to update to 3.80~33 → this fixes the issue to get my PV’s in the device list.
That still doesn’t address the issue of the “undeletable” Huis PV inverter…
VRM Portal ID: c0619ab85b0b
VRM Site ID: 945308
