Ralphie
(Ralph)
21 July 2025 10:29
1
Goedemiddag allemaal,
Mijn systeem draait al enige jaren als DESS en nu wilde ik de Cerbo GX updaten van 3.5.4 naar 3.6.3.
Dat ging zonder problemen.
Daarna begon de batterij te laden. Ik dacht: even wachten. Volgende ochtend 100% en geen ontlading. Verder onderzoek bracht aan het licht dat het DESS item uit het menu van de Cerbo verdwenen was en ook op de VRM site.
Downgrade maar 3.5.4 → alles werkt weer.
Wat zie ik over het hoofd?
Gr.
Ralph.
mpvader
(Matthijs Vader)
21 July 2025 10:57
2
Hi Ralph,
Thank you for the report. We’ll check. Is it om for an engineer toog into the system when required?
mpvader
(Matthijs Vader)
21 July 2025 12:36
3
And is it ok for us to update the system to v3.63 again ourselves when looking at this?
Its not a wide spread problem, which is why we’d like to see it happening on your system.
huib
(Huib)
21 July 2025 17:54
4
I had the same problem with 3.63 a couple of days ago, so i reversed back to 3.62 witch instantly solved the problem.
Just tried to install 3.63 again and this time dess was working as it should.
I was running ess without dynamic pricing when first install failed. Maybe thats why the setting disappeared in the vrm menu?
Tomorrow there are sufficient price differences so dynamic ess is benificial again and i had dess settings applied recently
mpvader
(Matthijs Vader)
21 July 2025 18:43
5
Thanks both. We found and mostly fixed an issue today that explains this behavior, including that it happens only sometimes.
Will be available as a beta version first and then an official release quickly as well.
Matthijs
For what it is worth, I had the exact same issue. Happened some time after upgrading. Reverting to 3.62 made DESS re-appear. I will stay at 3.62 until 3.64.beta is released.
Ralphie
(Ralph)
23 July 2025 19:14
7
Hi Matthijs,
Sorry for the late response. Of course an engineer may look in my system. What has to be done to enable that?
Regards,
Ralph.
mpvader
(Matthijs Vader)
23 July 2025 20:28
8
Hi Rob,
No problem. Meanwhile we’ve found, and fixed an issue that explains exactly what happened on your system.
Now available as a beta version. (v3.70~19 and later)
And soon as v3.64 official
Ralphie
(Ralph)
23 July 2025 20:33
9
Hi Matthijs,
I’ll wait for the official release and install it then.
Ralphie
(Ralph)
31 July 2025 16:50
10
Hi Matthijs,
I can confirm that 3.64 fixed this issue.
Kind regards,
Ralph.
mpvader
(Matthijs Vader)
31 July 2025 17:03
11
Hi @Ralphie good. And nice to get it confirmed as well.
Thanks for that!
Matthijs
