Since updating the firmware from 3.67 to a later version, the DESS function keeps switching off every few minutes. I don’t get any fault notification.
A long time ago, it started when I upgraded from 3.67 to 3.68. I then reverted from 3.68, and since then the problem has not occurred again.
Yesterday I updated to 3.75, followed by 3.79 and 3.80~44, but the problem persists. And now, of course, I can no longer go back to 3.67.
Thanks, I’ve manually reloaded 3.67 large as well, and everything is working properly again (at least, DESS no longer switches off automatically all the time).
The reason I wanted to update the firmware was to experiment with Shelly equipment. For example, to run a heat-pump water heater at the right times. But with firmware 3.67, that’s a bit more difficult again.
I’m wondering where things are going wrong. Anyone?
