With the introduction of the new strategy types and reactive strategy some unwanted behavior was introduced.
If the DESS system is configured for trade mode AND the consumption forecast is higher than the solar forecast AND there is no reason to buy or sell, the result is PROBATTERY with IDLE_MAINTAIN_TARGETSOC.
But if the consumption and the solar forecasts are wrong, solar is charged into the battery and consumption if temporarily higher than solar will be taken from the battery. Introducing about 20% losses and battery costs for each kW until you reach targetsoc again after which consumption is taken from grid. Another example is that solar production is high and consumption is very low causing all solar to be charged during very high prices in the hour before the system decides to sell to grid.
In a green mode config this seems a wise decision but in a trade mode config in the Netherlands with buy = sell this is not the correct strategy. In the pre-reactive builds <3.60, DESS would either buy or sell and just stay idle and use grid.
@Barbara would it be possible for the scheduler team to have a look at this please. I have seen the same behavior on the system of a friend but during summer without an EV he hardly ever has a consumption forecast higher than the solar forecast during idle moments. In my case it’s mostly early morning and before dinner. But I’m worried for winter. If no trading opportunity for the day, sunny and cold, consumption forecast will be higher than solar forecast quite often during mid day causing losses on all PV if not consumed directly. Truth be told, in the Netherlands with salderingsregeling, the grid is just a far cheaper battery during those hours.
