The overall result of DESS mainly depends on forecast accuracy, that is an open secret, I assume.
And one of the core issues seems to be unrealistic consumption / solar forecast, that leads to unexpected behaviour. While there is just a topic from today stating that the consumption forecast is “to high” - i’m having the opposite issue: Consumption Forecast is far to low.
My home is running 24/7 with a minimum consumption of 650 Watts. It won’t go bellow that, if every optional consumer is turned off. (There are servers, switches, infra stuff - the basic socket amount is 650 Watts)
However, DESS is predicting consumption values of down to 200 watts during night - There shouldn’t be any data of the past 3 months backing such a low consumption, wonder how the forecast is making this decission?
Heres the forecast of “today”, snapshoted yesterday, from 0 - 6 DESS is assuming a per-hour consumption of 200-300 Watts only - 50% of what WILL be used for sure:
The result of this is, that the system will not hit the morning with it’s predicted SOC of 30%, but in fact run empty (20% minimum soc) and then HAS to pull from grid:
finally, this is happening with a bad timing, DESS seems to believe till the end that there is no Battery-Charge required. If it would have noted earlier, that it will run out of Battery, it COULD have charged from the grid for 28 cents, rather than beeing FORCED to pull from grid in the expensive morning hours. This morning not much of a difference, tho.
A Second thing I noted and which I don’t understand:
The schedule seems to ALWAYS target for a 20% at the End of the day:
There is grid2bat scheduled for the cheapest hour today, that is fine - but Why 20% at the end of the day? That means basically “minimum soc reached” when the next day starts.
This may adjust as tomorrows prices will be coming in during noon - however then there is only “half a day” to compensate for any required offset. Wouldn’t it be more reasonable to pick some “Safety distance” towards the minimum soc during scheduling until tomorrows prices are known?
I mean now, the whole schedule for today is targeting a “empty battery” situation at 0 o clock tomorrow. So, the schedule has to be changed and some additional 8-10 kWh would need to be gathered from “somewhere”?
Additionally, the system is still expecting some 20 kWh solar today (forecast yesterday: 35) - which is not going to happen with a very high certainity.
So, beside wrong consumption / Soc, DESS also has to deal with a solar prediction of 35, of which we have gathered a stunning 3.1 kWh so far (13 pm)
