DESS prediction issue
Since a day or two the predictions (usage, grid, battery), as they are visible in VRM, stopped functioning properly. Only the solar prediction is there and makes sense. Specifically, the usage prediction is static at 3.5 kWh for each hour (way too high) and the system seems to fail to predict when to charge vs discharge. See attached screenshots. Is there a way to resolve this?
Overview
energie prediction
planning
Click on the grayed out legend entry for consumption prediction - you just disabled that.
Thanks. Does not solve the prediction though:
This is for tomorrow
The forecasted usage is equal to the VRM setting Dynamic ESS Max Import Power
Forecasted usage is now at 173kWh for tomorrow. Actual average usage is below 17 kWh, and always below 20kWh
I have experienced the same problem
An option to reset consumption forecast would be very welcome
